Ford focus 2014 immobiliser active
Hi
I have a 2014 Ford focus diesel. I have an immobiliser active check handbook error when I try and start the car.
eventually it will start
 have tried new battery in the key fob. New keyfob. Changed the ignition barrel sensor.
does anyone have any ideas of what to try next?
thank you
Updating your profile ? 🤣
You need to use FORScan so that when it doesn't start you can see what the DTC is. For example: It could be 'Key not detected' or 'Immobiliser ident mismatch' but you need the code first.
