Ford Galaxy 2009 2.2 P2033 EGT Sensor Location
Hi guys, My dad purchased a Ford Galaxy 2.2 tdci on 2009 reg getting a code for,
Code: P2033/P2033-C. Exhaust gas temperature sensor circuit High Bank 1 Sensor 2
Where can I locate this sensor is it easy to gain access to it or will I need a ramp etc
Does anyone have a diagram or can you explain how to get to it thanks all
Fixed replaced the EGT sensor filled the car full on fuel and did 200 miles DPF did a regen no more codes happy days
Next Issue,
I've noticed at around 65mph 70 mph the car is shaking I can feel it thru the wheel a tad and I feel like it's worse from the rear if that makes sense if I do 80-90mph it's gone and the car drives spot on what I've done so far,
Full lazer4 wheel alignment and tracking, 4 new tyres and Weights done and balancing, I tested the car prior to getting this work done and after the car is exactly the same vibration/wobble at 65-70 gone at 80 I would take the wheel from my galaxy but it's in Spain right now maybe one of the alloys could be bent slightly but no one said anything when getting the work carried out, took the car back and they said it all checked out perfect so I'm lost now, Maybe I should swap the front and rear tyres and see if anything changes?
Does anyone have any ideas on this anything else I should be looking out for or missing?
Cheers all.
