E-Bike Advice.
As i live local to the place i volunteer like a few miles and can get there all on canal paths i was looking at a electric Bike.
I cant afford a lot so a range of around £60,not bothered if its a top make as long as it works ok and a good range.
There are so many cheap name/makes out there so just a bit of advice one what to go for ( battery/motor size etc) i like the fat Tyre ones.
I have a normal Carrera one now.
Thanks.
3 hours ago, jace1969 said:
I cant afford a lot so a range of around £60,not bothered if its a top make as long as it works ok and a good range...
£60 sounds awfully cheap for an electric bike??
Carefull how you charge a cheap electric bike.
I own this GoGoBest GF750 (Dual Motor, 48v, 17.5ah, 2kW) Your looking at about £1-1.5k for a decent 4" fat tyre ebike
Oooft 6kph, I would budget for  leathers and a lid with that kinda power🤪😂
As a side note...
Volts=Max Speed
Ah=Range
KW=Acceleration/Torque
kinda🙃
Stick to pedal power .
An Acoustic Bike😂
i was thinking that,on some it says they deliver then you pay,the main place i see all these are on Facebook Market place.
I know the charging with the fire risk on some of the batteries but i just was seeing if anyone on here have seen them.
Aahhh, FB MarketPlace. The ideal place to order a device that you plug into your domestic mains, which can potentially burn your house down 😨
