Front and rear fog light failure, reverse light, rear windsh
Hello,
I have a 2008 Ford Focus mk2.5 1.8 TDCi.
I no longer have front and rear fog lights, reverse light, rear windshield wiper, or windshield washer pump.
Here’s what I’ve discovered:
- I have 6 volts at the fuse for the non-working elements when I try to activate them with the stalk switches.
- Sometimes when I try to turn on my front fog lights, my wipers activate on their own.
- When I remove a ground in the trunk on the left rear pillar and press the brakes, my front fog lights and washer pump work again, but nothing else.
Here’s what I’ve already done:
- Checked the fuses
- Checked the grounds
- Changed the stalk switches
- Rebooted GEM with FORScan
- Rerouted certain grounds, including the wiper stalk ground, resulting in the fog light indicator disappearing when they are supposed to be activated.
Here’s what the AUTEL scan tool says:
- B2115
- B2086
- B2035:20
- U0201:20
If you have any ideas, I’ve been searching for two weeks now :(
Thank you very much.
Either water ingress damage to the GEM (95% guaranteed)
Or Instrument cluster solder fault (But I doubt it)
All of your issues are the lower left hand fuses in the diagram.
I would start by checking the GEM connector C96 Pin 21 (the large central pin).
I'll up that to 99% failure of the GEM due to water ingress 🙁
I disassembled the GEM, but there are no signs of oxidation or water infiltration 😣
Regarding the solder joints behind the dashboard, I had a similar issue before, but I recently resoldered everything.
For the GEM connector C96 Pin 21, I will check if it is properly engaged and without any signs of corrosion ?
Additionally, I have a blue connector at the driver's footwell, and when I disconnect it, all the fog light indicators come back on.
Do you think a relay could be causing this? Considering that I haven't seen a relay related to all my problems, and my low beams are working.
Thank you !
up 🙂
Have you got 12V on connector C96 pin 21 when the ignition is on ?
No i have 6volt like fog lamp...
Do you have an idea ?
The cable go to the motor bay ?
Guys i did it !!
It was the ignition relay !
Thank you !!
