S-max transmission limited problem
My 2010 Ford S-Max Automatic has an amber indicator message confirming the message to be ‘Transmission Limited Function’.
When this light appears the gearbox loses the 1,3,5 and reverse gears while driving
When switching the car off and on again the car forget about the message I now have all gears for any time from 10 minutes to 30 minutes.
I took it to a car garage and they advised me to change the gearbox oil and still the same issue.
Anyone who is willing to share their experiences and resolutions would be very much appreciated.
Thanks James
Is this Powershift or AWF (torque converter) gearbox?
At 2010 that'll be the AISIN I reckon.
Doesn't sound good.
Get yourself set up on FORScan and when the vehicle goes into fault mode read the codes.
Could just be a sticking/failing solenoid
FORScan
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
