DTC Codes
I have the following codes when I do a dashboard dtc check on a Focus 1.0l 2015.
C100_00.
1607_82
C073_88
C140_00
C200_00
C121_00
I understand these are communication codes, and they have caused the orange MIL light to come on. The car has not been modified and was serviced in March.
How do I get these cancelled without a scanner and do they indicate an underlying fault(s)
Any help appreciated.
Instrument cluster codes are not of any use when trying to diagnose a problem. You need to get the Diagnostic Trouble Codes (DTC's)  using FORScan, windows laptop or phone version will both work.
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
Thanks for the reply. Can these codes be deleted without a scanner in any way or is it only possible with Forscan?
No.
They require clearing with FORScan or a compatible code reader.
Ok thanks. Car is not exhibiting any problems other than the warning light so it looks like I will have to get the necessary cable to sort it.
