Focus MK4 1.5 EcoBlue - Clutch/Flywheel kit
DMF has gone on my 2019 Focus. Had a look online, but could anyone confirm what the correct parts are for a clutch set kit for the MK4 1.5 EcoBlue Manual Focus?
A lot of the reg input ones aren't coming up with anything. My local garage is quoting nearly £1k for parts but I believe that's from main dealer, so want to avoid that one. I'll likely only have the car another 12 months.
Or, if anyone could point me in the direction of a reasonably priced set would be much appreciated.
Thanks in advance.
Would the clutch from the same engine on a Kuga work, the part number is slightly different though. Having trouble finding a decent replacement kit anywhere.
I don't know the answer, and the public parts catalogues don't cover the latest Ford models to cross reference.
However the LUK website is showing the same 3 piece clutch kit for the 1.5 EcoBlue on both Mk4 Focus and Mk3 Kuga.
LuK Clutch Kit LuK RepSet Pro 624 4104 33 (schaeffler.com)
If you want to post the part numbers that you've found, I may be able to find out what the differences are between them.
Thank you for this. Really useful as it also included the ford part numbers needed.
  • 2 months later...
Hi did you ever find out what you needed as I need the same thing and having the same trouble
