Fiesta Zetec S Ecoboost jitters at 50% throttle with EML on
Hi all, hope youre well.
i have a 2015 ford fiesta ecoboost zetec s. it has been newly serviced and drives fine until i hit the throttle about 50% and i start getting misfires with EML on the dash. it happens on all gears except first gear which is fine. the car drives and handle fine in general. has anyone experience this issue?
thanks in advance for your help!
Have you read the DTC'S with FORScan?
53 minutes ago, unofix said:
FORScan
no i have not. will it definitely show the fault code?
If you have had the EML on then yes.
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
@unofixis it quite common to happen especially to fiestas?
is what quite common ?
You haven't read the DTC's yet so the problem is unknown. Is it common for a Fiesta to have an EML on, Yes.
