Pre Heating Relay to glowplugs
HELP !  I have a Focus 1.8 tdci 06 mark 2 , I believe.  When this motor is running right it goes like hell ,BUT ! at the moment he,s a bit  unwell . It is in limp mode ( cog light with exclaimation mark in the middle ) had codes read but it does not appear to have any at the moment . This is what happened yesterday , I went for a drive in limp for about 15 miles then parked up in the sun , about 1 hour I started engine and the cog light went out and it drove good back home then the light came back on. I already have fitted new glo plugs, oil filter ,air filter , camshaft sensor , And glow plug relay which measures about 25 mm in size like a cube in the fuse box . But I also purchased a Preheating relay with bracket like end with a hole in it to fix it . It’s  about 75 mm long .So do you know where it goes on the car because I can’t find anywhere. There’s no sign of it any where !  I hope you guys can help with this , Rob Smurthwaite
I think you need to read the DTC's using FORScan.
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
