MK7 MILEAGE CORRECTION
so my mk7’s instrument cluster (9C110849DB) died and I’ve had to replace it with another used unit with the same part number but replacement part had higher mileage. Anyone got any software or ideas as to how I can reduce mileage to match existing unit.
TIA
Jake
Ford instrument clusters are designed that the mileage can only be adjusted higher, and can't be adjusted back.
There are a few companies that can set the mileage to zero, and then you can use FORScan to set the correct mileage.
That’s exactly the service I’m after. Can you recommend any companies? Or can anyone on here do it? Thanks
Did you or some electrics company look at your original part to see what had died ?
Repairable ? Most things are these days.
These people can apparently do it........
On 7/17/2024 at 11:07 AM, Jimpster said:
Reach out to Richard at Customod, or Ollie Jones both can be found via FB
