Ford focus MK1 2002 TDDi instrument cluster
hello everyone,
I have a problem with the instrument panel on a ford focus mk1 TDDi 2002,
When I turn the key to position ll, the speedometer rises to 60km/h and stays there, or while driving it rises/drops to 60km/h and stays like that. On the self-test, the movement speed reads normally
https://streamable.com/9318tc
If everything is normal for the gauge sweep test then it's most likely not the instrument cluster. If you have ABS then you'll have wheel speed sensors on most/all of the wheels. Alternatively you'll probably have a VSS (vehicle speed sensor) on the gearbox. The wheel speed sensors will connect to the ABS module. The VSS will connect to the ECU/TCM. The fault could be with a sensor, or the wiring, or a connector, or the ABS/ECU/TCM module.
the abs light does not shine, which would indicate a faulty sensor, would diagnostics be helpful?
