Ford Ecosport 1.5 diesel p1102 MAF issue
Got a 1.5 diesel ecosport that keeps having the powertrain light come up when the cars under acceleration. This then puts the car into limp mode. Switch the car off and on again and light goes out.
i have looked at the fault code which suggests the maf sensor air flow is in range but lower then expected. No running faults or anything noticeable with the car other then this.
i have replaced the maf and checked for air leaks but can’t find anything.
any advise would be greatly appreciated
  • 9 months later...
Hi, Did you ever get this problem sorted. I have the same problem ,I have changed maf/map and 02 sensor and egr valve done a smoke test and checked all the hoses but still goes into limp mode after driving for a few minutes, also cleaned out the egr cooler.
