Transit mk4 minibus tyres
Hi all,
I have a ford transit mk4 Asquith body minibus,on a twin wheel mk 4 with banana engine.
its 1 inch two high to go in my garage.
its fitted with 195x75x16 tyres,I understand if I fit 195x65x16 this will reduce the height by 1.5 inches.
what problems maaay I find if any by doing this ,or any alternative ideas.
many thanks
Is that a reduction of the radius, or the diameter.... ?
The first thing is you will need to use FORScan to re-calibrate the speedo which will be significantly wrong.
The ride and handling will be a lot harder.
VERY IMPORTANT: The reduction in height will only be 3/4 inch
https://tiresize.com/comparison/
Usually we'd lower the suspension rather than take an inch out of the sidewalls.  You might find it needs a bit of both as a compromise.
I'm not familiar with the suspension on a Mk4 Transit though.  Is it leaf springs at the back?
Yes leafs on back and single leaf on front
3/4 inch
No, only reduces the height by 3/4 inch
You may be able to buy different mounts or have the leaf adjusted slightly using heat.  It's probably worth asking over on the dedicated Transit forum as it's a bit too niche for this forum.
Don't put it in your garage. Sorted.
or just let the tyres down to put it away, and blow back up in the morning🤣
Yeah, I had thought about it too. Easy.  But why would you? I mean buy a MK4 transit mini bus . 🤣🤣
It’s not just a transit bus it’s a Asquith wedding bus built on a transit twin wheel base
