Ford focus mk2 not starting
So yesterday i drove the car perfectly fine i did around 150 miles and just got out now to start the car and no lights car wouldn't unlock so I  had to manually unlock to find out its not the car battery fuse when i turn the key in ignition nothing lights up at all and i have no idea what could be wrong with it please if anyone knows or experienced this help me out
Note: I did add abit coolant in as it needed a topup after that it started fine when i was driving yestesterday
Car battery fuse?
Sounds like the car battery is the fault if there's no electrics anywhere.  Either the battery itself, or a poor terminal connection or a broken battery cable.
Car battery fuse?
Hi thank you for replying can you tell me where the car fuse is located and what number is it ?
There isn't a car battery fuse.
If there are no electrics at all in the car, the problem is either the battery itself, or the cables to it.
Do you have a multimeter?
Hi no I don’t and the current battery I have in  wasn’t a silver one I’ve had it in around 6 months till now does it need to be silver ? Or do you know for the 1.6 mk2 what battery  Ah it needs to be and the A EN  ?
It should be Silver Calcium but they are hard to find now.
I don't know exactly for this engine but around 60AH and 600CCA should be more than enough.
Is  Bosch Silver Calcium good or does it need to be varta brand ?
Bosch Silver Calcium is perfectly fine.
Ok thank you ordered it will let you know if it works tomorrow
Yes the car started working after battery change thank you so much
