Mk2 2008 Ford focus
Is there a headlight relay in the focus of so where is it located
As far as I'm aware, the 'relay' is built into the car's BCM. What is the issue you are experiencing?
High beams working fine low beams not working
Try putting in a new working bulb. Often when one bulb goes (often unnoticed) the other will soon follow, I speak from experience...
As Stephen recommends, put a couple of new lamps in and you will probably be good to go 👍
LOL, just found my old post describing exactly the same issue - much humble pie was eaten 🤣
Replaced new bulbs and new fuses still not working
When you turn the dipped beams on, can you hear a click from the passenger footwell?
No can hear anything
I would guess that's the issue then, on switching on the dipped beam, you should hear a click from the BCM as the 'relay' activates. Maybe water ingress causing issues, the smart folk will tell you what to do now!
Thanks pal
Worth checking the switch as well.  Much easier to replace that than the BCM.
Ya thanks Will check that
My personal next step would be to check the operation of the indicator stalk for switching between dipped and main beam.
Ok will check that also 👍
