Headlight peeling
Hi I have a 2009 mk2 focus wondering top of headlights starting to peel any ideas will this need to be replaced cheers
You should be able to refurbish the headlamp.
I suggest using the turtlewax kit.
"Turtlewax Speed Headlight Lens repair & renew kit"
this phrase will find it on Ebay
There is a sanding pad included, if however the peeling is significant you will need to gently sand the lamp with a very fine grade of wet/dry paper before using the kit.
Cheers I will look that up on EBay give it a go
