Abs and traction light
I have an issue with an abs and traction control light staying on. I had the wheel bearing and wheel speed sensor changed but still no result. When I tested the plugs for the rear offside wheel speed sensor I was getting positive voltage but I’m thinking that there’s a short in the wiring somewhere closer to the abs pump but I’m lost for answers.
Have you used FORScan to read the DTC's ?
