Engine help!
Fitted a reconditioned euro 5 enging in a mk7 transit started and ticked over for a coupple of minutes sounded grate  reved the engine to 2000 rpm and the engine sound changed and sounded like it was firing on 3 cilinders turned it of struggled to start again now it wont start done a pressure test and 300psi in no 1 no compression in cilinder 2 50 psi in cilinder 3 and 300psi in no 4.
does anyone have any idea what this could be and how to fix it?
Contact the reconditioners.  Sounds like the headgasket has failed between cylinders 2&3.
