ST150 EML
Hi all, I’m wondering if anyone has any advice. My ST150 randomly cut out and showed a red engine fault warning. Car was misfiring and In limp mode. AA diagnosed it as the throttle body, replaced the throttle body with no difference. Then replaced coil pack, ignition leads and spark plugs, again no difference. A mechanic took the fuel injectors out and 2 of them made no difference to how the car was running, he cleaned them and put them back in and car was fine for a week. Now cut out and back to the same issues as before, I don’t want to keep throwing money at the car but also don’t want to get rid if there’s a simple fix. Is it likely that replacing the fuel injectors would solve the issue? Or is it more likely there’s a bigger issue which is the root cause?
Some of these had this issue when new, including one of mine, and it was the alternator
