Key not deteced
I have a 2013 focus SE, been having trouble with it starting. Would have to turn the key many times before it would finally rollover.
New battery
New key, cut and programmed
Starter tested and fine
New starter switch
New immobilizer
New negative battery cable
New ignition assembly
New trans neutral sensor
Now it just says "no key detected" Everytime. There is 4 keys programmed to the vehicle, And i have two of them. I have no idea what else to do and now I can't even get it to start now.
Any ideas or suggestions what to try next?
BCM maybe?
Well personally before replacing the many parts that you already have, I would have used FORScan to see what the reason is that it doesn't turn over.
On a 2013 Focus it could still be the infamous 'dry solder joints' on the instrument cluster. Next time you try to start it give the dashboard a good 'thump' with your hand just above the IC and see if anything changes.
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
The infamous 'instrument cluster' fault, which when I had before repair, caused numerous electrical gremlins...
Sorry guys, I didn't receive any notifications of your responses.
Originally I had taken the vehicle to a garage and they stated they couldn't do anything, that the only code they pulled led them to believe a new key was needed. I did that and then started replacing everything I could starting with the cheapest items.
I did try hitting try the dash as you suggested, with zero changes.
The most recent code I was able to pull was for the BCM (b10d7:05-2f)
New battery
New starter switch
New immobilizer
BCM maybe?
Do you live near any phone masts or TV transmitters?
