Please help..
I have a ford fiesta 2012 1.4 tdci manual.... had a p0606 code..  ended up changing the ecu with a cloned one... this code has now gone... recently changed fuel sender unit and crankshaft sensor.... but car still wont start... it cranks for a few seconds and stop all wires look good and fuses are all good and receive power plus relays... this is the report i had today from auto electrician il add here.... he said the abs pump has shut off and needs to be replaced.. i wanted to get some more advice....because i dont wanna keep splashing out on this... thanks damo
Firstly, why did you replace the ECU, (by which I'm guessing you are referring to the PCM) ?
Secondly, has the engine ever started and run since the replacement PCM ?
