focus sd card
hi all
what is the latest SD card for a 2016 focus est sat nav.
new car didn't come with card
thanks
The latest is the F12 maps for a 2016 model.  £24.98
https://www.ebay.co.uk/itm/387596262393?
thank you
Just FYI a lot of these F12 are fake. They are at best F11 with modified info.
insert sd card and have installed card and still getting insert sd card
F12
Afaik there no F12 cards it will be fake although some of the fakes are using older genuine maps with a modified version number so might still work.
Do you know if the car came with navigation from factory?
i believe it was as i have been on the ford site and it says maps up to date
but no card when i brought the car
not tried it yet will plug a lead into it
just plugged phone into usb and works fine
What is the build date of your car ?
Is it before or after 3rd August 2016
not sure on build date it was first reg in march 2016
So we can safely say it was built before 3rd August 2016.
I'll have to refresh my train of thought now, I've forgotten what I was thinking 🤣
Also is the sd holder all ok - when you insert a card it should go fully home and "click" into place.
To remove a card you need to press it inwards slightly first, then release pressure and it should pop up proud of the holder
sd holder seems ok does click when inserted and pops up when pressed again going to get a garage to check it is working
Do you know anybody else that uses ford Sync2 - does not matter how old their sd card - just try it to see if it confirms your veh is ok and the card you have is therefor faulty
thanks to all i brought a different SD card and all is working
