Galaxy ignition turns on but turns over intermittently
hi there
My ford galaxy ignition turns on but then when you go to start it it doesnt turn over.
I dont think it is the starter , could it be the ignition
To eliminate the guess work, use FORScan and monitor the start circuit. It could be quite a number of things from as simple as the start relay, to a bigger problem with the PATS system.
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
Thank you for your advice
i think it was a faulty starter relay because i took them out and then put them back in again and it working fine now
