Mk 4 code reader
Morning.
I need a recommendation for a fault reader for a 1999 Mk 4 Fiesta.
I don't have the car with me at the moment to check what port it has.
It's been at a garage for a month now, and is getting pushed to one side on their work schedule. They just admitted this week they don't have the gear to check the faults, so I'll probably now take it elsewhere, but would like to check the faults myself
The main problem is it was standing for the best part of two years. Would crank, but not start. Fuel pump and filter was changed, and new fuel put in. Not clear what else has been done.
Apparently it now starts, but is very rough and spewing white smoke from the exhaust, which sounds like a head gasket. Have asked for a block test to be done before making the next decision.
Cheers,
Nick
Generally we recommend Forscan but I doubt that has much functionality on a Mk4 Fiesta.  You would probably need to find someone with the actual Ford software from the time which I can't imagine is an easy task.
At this stage I'd just like any lead on why the car won't work. What port does one of that age have?
It has an OBD port.  But generic OBD software doesn't tell you much.  Every garage will have a generic OBD reader so I would assume they've already tried that without getting any useful codes.
I would have assumed the same too. Will have a chat with them tomorrow. Thanks.
As a matter of interest by the way, would it be OBD 1 or 2?
Caveat the post.. it's a 1997 Mk4
It's an OBD2 shaped port.  But may not be fully OBD2 compliant at that age.
Brilliant..  thank you.
You could give the Windows Laptop version of FORScan a try using the vLinker FS it may at least show all of the generic codes and what few Ford specific codes that were used on the Mk4 Fiesta.
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
Great.. thank you.
