Ford focus estate 2015 1.5
Just a question  finding out that my left brake hose bent so had to get a new one  but couldn't  get the sliding clip back on. So had straighten the bent hose part temp fix. Did the bleeding the brakes but suddenly  my clutch peddle sticking once or twice then half way. But after a few mins ok. Clutch is fine.  So is the brake fluid  and clutch  a same system possible air trapped?? Need proper bleeding the system ? Thanks
They share the same fluid reservoir.
So possible air trapped so bleeding  it out would be a suitable option?   Thanks
I'm not sure how easy it is to bleed the clutch on your model.
Yeah I haven't found  out yet I.ll bleed the brakes 1st do bit by bit cheers
Just searched on YouTube. Been watching that's possibly easy check the pedal spring common fault cheap change. Steeda spring clutch return spring. Going to try that
Change the spring better only a bit so I think because  I tried tried the brake hose possible air trapped.  Will bleed the system  what's the best way to bleed it ?
Spend £50 and take it to .....
  • Halfords
  • National Tyres
  • KwikFit
Or any of the garages offering 'brake fluid replacement'. They have all the gear to vacuum bleed the system and refill with new fluid.
