Ford Focus Mk 4.5 Mild Hybrid
Just got my new Ford Focus Mild Hybrid, and on reading the manual it says that the engine will switch off when coasting at a speed less than the engine stop speed that you set.
It then says to set the engine stop speed I need to go into the following:  fetures/Driver Assistance/rolling StartStop:speed Threshold.
The problem is I dont have that option in the menu.
Does anyone know how to set the rolling startstop speed.
Do you have the digital dash?  If so, it may be on the dash screen rather than the Sync touchscreen.
Yes i have digital dash, but not on there either.
I think i might have sorted it.  Looks like the rolling start/stop settings are only for manual cars, and mine's an automatic
Ok, it was on the digital dash in my pre-facelift model.
The only options are that it's under a different heading, or they've removed the option to change it.
If you can take some photos of the menu options you do have we might be able to work it out.
Ah, that could be it.
I would think that you're right 👍
