Is cruise control compatible on a 2010 zetec s
As titled, can it be fitted? Is it already wired and just needs the usual additions and activation?
2010 zetec s 1.6 diesel manual TZJA engine
12 hours ago, SquidgyB7421 said:
can it be fitted?
Yes
Yes & No
You need the steering wheel switches, obviously, but then you need to make sure the column stalk clock spring supports the wheel.
Take both from the same donor.
Then configure
3 hours ago, DaveT70 said:
But then you need to make sure the column stalk clock spring supports the wheel.
This is what im asking about. Id just be changing the surround to add the controls. Just wanted to know if its straight plug and play on my model, or not.
It is, apart from the clock spring.
Get all the parts from the same donor
or not would be the answer.
Thank you.
Recommended donor model I should get these parts from? Just any titanium?
Or if possible, the part number for a unit that would work.
Purchased these from reclamet. Off the same car.
Without sounding offish, any donor with cruise control
