Mot fix Mk2 Focus
IMG_7152.thumb.jpeg.b3b4d0a8ef616c0768d9db877ae141ef.jpegNeed a bit of plane English maybe photo of item if you can help much appreciated is it going to be costly can do spring maybe do others except welding cheers
You have a decision to make. That welding sounds about £400/£500 alone. Then you have the other suspension repairs on top of that. I note your location is Co. Antrim. No idea whereabouts, but a couple of years back, my 2005 Mk2 failed on sill rust hole, and I got it repaired in HT Motors in Doagh. At the time it was around £300  for just one side, but they are excellent. You may be able to shop around for cheaper.
The sensible thing is to cut your losses on a 2009 car, and move on. But if you're really attached to the car, that's your decision alone. Let us know how you get on...
I think it's a pair of these that you want. There are two Ball Joint sizes, 21 and 18mm, most are 21mm but you will need to check your one. FORD FOCUS MK2 FRONT LOWER SUSPENSION CONTROL ARMS WISHBONE WITH 21MM BALL JOINT | eBay
The Rear Springs are a strange shape and not easy to replace without a special Spring Compressor, most normal ones will not work, unless you want to do a lot of dismantling.
I agree with Stephen about the Welding, it will probably be expensive.
The sensible thing is to cut your losses on a 2009 car, and move on. But if you're really attached to the car, that's you decision alone. Let us know how you get on...
Cheers Stephen yeah thinking time
Thanks tizer check that out
Checking out front suspension arms easy enough to do spring looks not to bad just the welding repair is gona be challenging maybe try a few places first I think the suspension arms should cover all the suspension problems ok
In theory you can just replace the Bush and Ball joint but it is a lot more work and probably not any cheaper because you may damage other parts when dismantling.
Yes I agree 100% just knowing the size of ball joints for replacement arms  19 or 21mm probably 21  tdci model suppose if put in reg should be correct 👍🏻
In regards seam repair at rearmost must be under plastic trim cut piece out set peice in mig weld repair hopefully do
all three issues normal
100 quid on second-hand rear spring and two new front lower arms, (if you fit yourself) then try and go elsewhere for a retest
he was probably having a bad day and fed up with drivers that can't notice the back of the car sitting at a funny level - so once he found two real faults the rust was just so he didn't need to see it again
Yeah I guess that but he left two holes on either side of sills with a screwdriver have to get welded cheers for your comments bud
they are NOT ALLOWED to smash holes in your car.....
Yes they are.  There's even a special tool for that exact purpose called a corrosion hammer.
SEAH1MOT.jpg?v=12.10
And they are supposed to just tap it lightly with the hammer and tell from the noise whether it is corroded.
To be fair, when mine failed on corrosion to the sill, I was really miffed, especially when I saw the hole that I hadn't 'noticed' before. But the over riding factor was that I was happy that after repair, I had a safer car to drive....
Crikey. I almost thought you were joking there until I looked up "DVSA approved corrosion assessment hammer" and got loads of hits (no pun intended😀).
It's fortunately many years now since annual welding was part of my pre-MOT preparation, but as I recall, you never needed a hammer to find the rust - with the cars I had then, poking your finger would do the job. Perhaps modern rust is better quality!
My usual MOT station told me they have seen a modern Jaguar with a badly rusted rear sub frame. Apparently so badly rusted you could push your finger through it.
This was in the last few years. The car was less than five years old at the time.
The hammer head is plastic, which is difficult to tell in the photo.
It's a different system in Northern Ireland, all vehicles are tested by their equivalent of DVSA, and it can take ages to get a test slot!
It's the DVLA, and 7 months isn't long, is it? 🤣
They are also used to detect if someone has covered up a rusty part with Fibreglass and undersealed over it, that would make a different noise compared to a bit of metal.
I have seen them being used during a MOT, maybe because I was watching .
Those Mot guys know exactly where to look on every car for corrosion and on mk2 the rear sill is a hot spot for rust the use of a plastic trim around the inner arch lip probably would have prevented this a tiny stone chip in the paint probably snowballed into this
my sister's X type just failed for this - remember its a mondeo !!!!
you're allowed to tap things gently with approved tools - you are still liable for damage caused
