Ford fiesta 2012 1.4 tdci
Hi guys....Where is the low pressure fuel pump or fuel regulator located... its not in the sender unit so i can see its in the engine... and the high pressure fuel pump is ok... i wanna check the above... but cant seem to find nothing online as to where its hiding...
I may be wrong, and quite likely am, but from what i can read, the high pressure pump has an integrated transfer pump and that is the lower pressure pump. Its all sucked and the sender unit is just a flow regulator.
Fuel pressure regulator is on the HP pump.
