P2563
I have this P2563 error code on my Ford fiesta 2015 1.6 diesel
took it to garage they said it’s the turbo
changed the turbo, the light still came on couple of days later
another technician told me to change the Mass airflow sensor that also didn’t fix the issue, in this form i saw someone mentioned about looking at the wiring, i took my time to check all the wiring connected to turbo, and nothing was wrong with it, i still have this issue, i clear the light using my OBD reader and still comes on afterafew miles
please help
From memory I think it's the turbo boost controller..
Get someone else to start the car and watch the actuator arm on the turbo to see if it moves and stays there..
If it dosent then replace but not with an eBay special (don't seem to work)
Or one of the 3 pipes coming from it may be split
I have included the transmission breather hose picture above which i checked was broken in my car, does a broken transmission breather hose cause this fault ?
i have purchased the transmission breather hose from Ford, but don’t know where to connect it to
