Ford C-MAX 2013 - Won't start after engine replacement
Hello,
I have an issue after replacement of engine 1.0 ecoboost 125hp M1DA, the car won't start and the only code are P0106.
The new engine are naked but closed with a new timing belt (Refurbished as a new engine).
I have try to change the manifold pressure sensor and boost pressure sensor, when the MAF sensor is out of the hole at air the car have no obd code but won't start too. I have test the MAF sensor and react of wind, the values changes.
I think is a common failure, searched on forums customers have the same issue after engine head up replacement but after don't reply.
Do you have a solution please ?
Are the right connectors on the right sensor. The map sensor and cam position sensor connectors actually fit either sensors and causes engine non start.
