Dtc code 5359
Does anyone know the DTC code 9359 Main on a Ford Fiesta semi auto
Usually a full code needs P, U, B?
Nothing here: https://www.dtcdecode.com/Ford
https://www.obd-codes.com/forums/viewtopic.php?t=771
Any obvious effect on perfomance etc?
Plus, as usual, Forscan is the best way to get some sort of idea/comment?
Ignition fault.  Most likely just low battery charge.
If after checking the battery voltage you find it is OK (better than 12.40V) then check the fuses marked "IGN" and also "START" the labels are shown on the fusebox cover.
See handbook for more details of the fuses: https://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?variantid=1114&languageCode=en&countryCode=USA&Uid=G958569&ProcUid=G958570&userMarket=GBR&div=f&vFilteringEnabled=False&buildtype=web
D262 code aswell
Ignore instrument cluster codes.
Get a reader or, more importantly, get set up on FORScan and read the real codes properly.
But, as previously advised, check battery is performing well, check, adjust and lubricated shift mechanism:whistling:
