Fuel Error Help Needed
Hi All
Does anyone have any ideas what the problem is
when I go on the motorway and accelerate hard it goes into limp mode
Any ideas ?
Diesel fuel filter is blocked ? 🤔
I have just had a new one put in
Did you have the problem before you changed the fuel filter ?
Yes mate
Don't understand the first code,  is it in limp mode , last two would normally indicate fuel blockage or filter sorry for edit update...
3 minutes ago, Shearers said:
Next step is fault codes when it is in limp mode and we (that's the Royal We on here) recommend Forscan and a lead?
That’s the reading when in limp mode from a Snap On Machine
Sorry, I can only add my edit above as I hadn't read that in detail?
First code may be the first one to go for , I think it is a throttle flap somewhere but never dealt with it?
