2007 Fiesta intermittent engine light
Hi all, I'm new to this page.
I have a ford fiesta 2007 model, I was leaving our drive, when the yellow engine light started to flash for a couple of minutes, then stopped. I'm concerned that this will be a big job because of the age of the car. What could the issue be as I'm no engineer. Could it be a simple fix ad it intermittently comes on then disappears.
It could be any one of a thousand reasons. The fix might be a £20 sensor or a new engine. You need to get the Diagnostic Trouble Codes (DTC's) read using by either a Ford garage or do it yourself using FORScan. Only when you have the fault code will you be able to find out what the problem is.
