Engine fan staying on when engine is hot
Hi does anyone know what the problem could be focus zs 2016 1.0 fan stays on when engine is hot msg pops up saying engine temperature warm engine speed reduced car doesn't overheat had AA out he reckons blockage in radiator
Check the grille shutters aren't stuck closed.  And the electric coolant pump, if fitted.
Interesting you say it doesn't overheat though?  A blockage in the radiator would make it overheat.
No mate no overheating issue like I said if do around 60mph it goes into limp mode msg pops up saying engine speed reduced due to lower temperature
Ok, you'll need Forscan on it to read the Ford specific fault codes in that case.
Forgot to say if I don't keep the heater on inside the car while driving it starts to overheat
Thermostat is probably stuck closed in that case.
