Ford Galaxy 2016 High Pressure Fuel Pump Location
Hi There
Does anyone know where the Ford Galaxy 2016 High Pressure Fuel Pump Location is please
Its a 2.0ltr Turbo Diesel
Phil
Right hand side of the engine, above the gearbox.
Is it easy to get to from underneath?
Ño it's on top, driven from the camshaft.
For a 2L Galaxy engine at least, you can easily trace the fuel line from the filter to the pump as they are all on the top of the engine block, placed left to right as you are facing it. The fuel pump is fastened to the top right of the engine block.
Why does @Philzilla86 want/need to know?
This is normally a very reliable device not to be disturbed...
Not that reliable,  the springs inside snap loosing the pressure. Also suffer from oil leaks from the gaskets frequently.
2 hours ago, iantt said:
Not that reliable
Well, not having had problems yet, I'll watch for that, Thanks
