DPF Soot Load
Hello All,
I'm trying to fix my smax 2011.
Had several dpf warnings up including limp mode.
Eventually cleared them down using Forscan after I cleaned the dpf filter.
But I'm stuck with the soot load % at 300%.
I can't seem to reset it using Forscan.
Has anyone managed to clear this before?
Cheers.
I don't know if you can see/have used a "Reset the diesel particulate filter learned values" in Forscan BUT this shouldn't be done until you are certain that the DPF is thoroughly clean and the differential pressures at idle and 3000 RPM are acceptable, perhaps:
Idle 2-10 mbar (0.2- 1kPa)
At 3000 rpm, 40-80 mbar (MAX 100 mBar, 10 kPa)
Ideally at the lower end of both of those (sometimes the sensor values go up in units of 10 mBar)?
