Fiesta ST150 interior scan fail
When I lock the car and either someone is in it or one of the doors are open, the hazard flash as if the alarm goes but no siren triggers. I have looked to see if the horn works but that’s all fine. When I plug a diagnostic scanner into the car it tells me the interior scan sensor isn’t working but I know it does because if the car is locked and someone is inside the car, the hazards flash. Does anyone know if this is a common problem and how to fix it?
Thanks.
Is that the normal car horn, or the horn for the alarm system ?
Normal horn
So the horn for the alarm is not working
Are you using FORScan to read the DTC's ?
Yes, I use FORscan
