ford focus 1.8tdci
runs for short periods of time then you stop shut the engine off and then try to start and dosent start just winds over and if it does start just cuts out  any one had this fault
Read the fault codes DTC's using FORScan and then let us know what have.
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
OR
For diagnostic use only:
Search Tag:   FORScan123
Bit more info useful, e.g. did it start with occasional problem and get worse or suddenly change, is engine management warning light on, did problem start after refuelling. Potentially air in fuel line or blocked fuel line?
