Engine malfunction
Hi All
Has anyone got an idea why my focus is ok then then loses power ie going up hills but is ok again after that
Turn off and restart light go's off then will come back on after asking for more power to get up hills ect
Not enough info (for me) to make any judgement at all, need fault codes whilst presumably EML is on?
Use Forscan and lead if you don't have a scanner, or even if you do (as it reads ALL Ford specific codes)?
Thankyou not much else I can tell you to be honest apart from losses power noticeable most going up hills when asking for more power this doesn't happen all the time though I haven't got a cable so I will invest in one and see what codes come up
Is there any cable you would reccomend as there is a few outt there
@unofix says...
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
OR
OBDLINK EX, cable for laptop: https://www.amazon.co.uk/OBDLINK-EX-FORScan-OBD-Adapter/dp/B081VQVD3F/ref=sr_1_5
For diagnostic use only:
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Live links:
OR
Search Tag:   FORScan123
