Fuses
Hi I am new to the forum and I'm just wondering on my Ford S Max 2.0L TDCI how to get to the F3 F4 F5 fuses I have found where they should be under the bonnet and can see the the numbers for where the fuses should be but it looks like the black plastic on top is stopping me from seeing them does this slide off or not I don't want to break anything Thank you to anyone who can help.
I have took the top of the fuse box off I did that and can see all the fuses before putting anything on here I mean there are 3 fuses that can't be seen when you take the fuse box top off and that's F3 F4 AND F5 that's the ones I need to access and don't know how to
Not all fuses are fitted to all models.
Are you saying that the spaces for these 3 fuses are there but they are just not fitted, OR, the fuses are fitted but for some reason you can't reach them ?
If there is an additional cover over these fuses then it will just un-clip by pulling upwards.
Okay thank you buddy will give trying to get the other casing off
