2007 Ford Fiesta Zetec rear passenger door window removal
Hi does anyone know the correct way to remove the rear left passenger door window?
They are manual on the rear electric on the front, I have tried but afraid of breaking the glass.
Many thanks
Wind down window
Take window winder off
Take door card off
Take inner panel off
Disconnect glass from regulator
Remove glass
Thanks Dave, not that easy tho.
Window winder off, door card off, inner panel all unbolted but doesn't want to come off as appears to be held by window glass.
I found a plastic tab which I pressed in and released the glass but that's as far as I get, there doesn't appear to be room to get the glass out of the door without trying to bend the glass.
You might need to put the winder back on to set the glass at the right height for disconnecting
