Cruise control activation
Hello everyone!
Does anyone here know anybody that can point me to the person that can activate Cruise Control on Ford Focus MK2.5 . I have swapped steering wheel for the one with controls factory fitted, done the checks , it’s all connected. Just need someone with the software to activate
regards Lubex
Why not do it yourself? All you need is a cable and a free forscan license? I did mine myself on my Mk3 focus, it took about 5 mins. This cable is the best value and one of the few ones officially recommended.
https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
I’ve got the one you recommended earlier if that won’t do it I’ll try this one
thanks
On 6/3/2025 at 7:45 PM, TomsFocus said:
I don't know which ones will work.  Some are very poor quality.  It's pot luck now that Tunnelrat don't sell them anymore.  They do offer some suggestions that they claim to have tested here.
https://tunnelrat-electronics.fwscart.com/
There is a newer cable used for Forscan (V-Linker) but with ELMConfig being a very old program I'm not sure whether it'll work with those cables.
The modified ELM cables have a switch for HS/MS CAN on them.  The standard cables don't have that switch.  You do need that switch otherwise you can't access all of the modules.
1 hour ago, unofix said:
Much appreciated! It’s on order, fingers crossed this time I can have my c/c activated!
  • 4 weeks later...
Hello again to everyone!
I would like to thank everyone for their support , patience and understanding!
I got my C/C working, I couldn’t do it without you guys and for that I thank you again. After all the trials and tribulations I got the result
never give up!
thanks again !
  • 4 weeks later...
Please advise on the specific setting you used to activate CC.
Hello! Sorry for the delay, I’ll post the link to the instructions , please bear with me.
Hello again! Above are the links to instructions, the second one is the simple instructions to activate modules HEC, GEM and PCM. Hec and Gem are easy but I had a problem with PCM ( Getting error non-empty VID block found in the PCM module. )
the top link is the instructions for this specific situation, if you read the whole thread you’ll understand hopefully 🤞. Let me know how you get on. Good luck
Ps read whole threads for but pay attention to the answers I linked
top link look for DanP he explains how to deal with the error message!!!
bottom link TomsFocus
This is the OBD that works https://amzn.eu/d/1lIto5F
