Focus Mk 2 clock cluster
Hi all,
I have been told to use Ebay, to have my clock cluster fixed and corded. Just been on there, with their being so many to choose from, I'm not sure where to start.
Can anybody recommend one of them they may have used please. All suggestions appreciated
Use @rd457
He will be along soon to advise, he has a listing on eBay.
16 minutes ago, unofix said:
Use @rd457
This is his listing, a fellow club member, jolly knowledgeable, and a decent chap...
https://www.ebay.co.uk/itm/314393033915
50 minutes ago, Artinwales said:
fixed and corded
I only repair the cracked solder joints, I don't do programming. Programming shouldn't be needed at all though unless you're trying to replace a unit.
I just assumed the OP mentioned, 'coding' as a fashion statement as most modern cars need everything coded, even headlights 🤣 I'd be willing to bet he means he just needs a proper solder repair to get the cluster working...
Thanks for your quick reply, I will send it to you when I've taken it from the car. Thanks to all the relies, much appreciated
