Kuga head gasket
My Kugas head gasket has blown.  I’ve been told it needs a lot of work, head gasket removal etc.  I’ve come across a product called Steel seal.  Would it be worth trying that to see if that can fix the issue?  Kuga is 2 l awd, 2015 plate
If it is genuinely only the head gasket that has gone and nothing else, then I would probably get the gasket replaced.
However if it is a cracked or warped cylinder head (or other cracks) then I personally would probably try K-Seal. If it fails you will need a new engine, but you're going to need a new one anyways if it's not the head gasket.
https://www.kseal.com/uk/products/k-seal-ultimate
