Parasitic Draw?
Hi folks,
Looking for confirmation or challenge on my thinking for my Ford Focus 2006 (MK2)
When I got it, the stereo didn't work, the unit in it was dead, none of the buttons worked. The light came on but not much else. I bought an after market stereo and installed it and all seemed fine until I realised something was killing the battery. Removed the stereo and the car was fine again battery had no issues. I assumed it was the aftermarket stereo, so I bought a second hand ford stereo the correct one for my car. Installed that but the battery started to die again.
It definitely doesn't do it with no stereo in. But has done it with two different stereos in. Which makes me think it's not the stereo.
What I did notice is only the front right  speakers work and the front left the little in door speaker works but the main one not. Neither of the rear speakers work.
My conclusion is, that the speakers may be damaged, badly wired and causing a parasitic draw. But as they are powered through the stereo it only happens when the stereo is plugged in.
Does this sound a reasonable conclusion? Any advice on how I can confirm this?
If you have the separate Bluetooth module then it is very probably the cause.
