Ford S Max 2.0 TDCI Sport 2011 won't start.
Hi, any help would be appreciated. I have an S Max that won't start.
I had the ECU repaired but car still won't start. OBD2 shows no fault codes.
R2 relay is clicking and battery drains relatively quickly.
I changed the crankshaft sensor, still no start.
The engine cranks over no problem.
I have pulled every plug and checked wiring and pins, found no issues.
Previous owner said they had the timing belt and water pump changed and the car drove perfectly fine, a week later the car started to play up and intermittently failed to start, finally it gave up altogether.
Any help would be greatly appreciated. TIA.
Ford S Max 2.0 TDCI
Recommend that you repost this in the S-Max forum.
https://www.fordownersclub.com/forums/forum/24-ford-s-max-club/
