2005 ford focus misfiring
Hi all, so I have a 2005 ford focus 1.4 lx, 2 weeks ago it started misfiring, struggling in 2nd gear etc. Turns out there was water in the spark plugs, no idea how it got there. Mechanic got rid of the water,dried it up, replaced the spark plugs, and I think the leads. Now I can feel it slightly misfiring again, juddering slightly when I turn a corner and now it seems like it's struggling to start. Car is fine otherwise, oil levels coolant levels both fine. 147,000 km on the clock. Any idea what could be the issue? Thanks in advance before I go to the mechanic again
You need a different mechanic.
Also you need to move from Louth since the rest of the UK measures distance in miles 🤔
 Nothing wrong with the mechanic, he's good, just curious as to what it could be. And what's louth got to do with it
It's where you say that you live 🤣
Have you changed the coil pack?
Was all the rust fully removed from the spark plug area prior to fitting the new plugs (earthing issue)?
Who needs a car when a car can be broken? :whistling:
@DaveT70 coil pack wasn't changed and I'm assuming he removed the rust
Never assume👍
Check & replace the coil pack then.
And ensure the HT leads were indeed changed too
The OP could be in County Louth Ireland where the road signs and car dashboards are in km.
As water got to the spark plugs, I assume the car is a Mk2. This is a common problem with this model.
Rain water can leak in around the washer jets and onto the valve cover. It then drips down around the plug caps and collects in the plug wells.
The other possibility is that the screen wash leaks out from where the plastic pipes fit onto the washer jets.
Thanks for that info.
I was not aware of Co. Louth Ireland only Louth, Lincolnshire 👍
Actually owning one of these cars, a 2005 Focus, I can confirm, that new coil packs, new spark plugs and new HT leads certainly cured the same fault for me...
Also have you had the breather pipe checked and core plugs? Exact same thing happened to me last year. Water in plugs and one of them seized. Changed plugs and coil pack and dried it all out. Broke down again next day with cylinder 2 misfire, turned out to be a split breather pipe and worn out core plugs. HT leads also tend to corroded for cylinder 2 especially (that advice given to me by a former ford mechanic who worked for them when mk2 came out)
