Ford transit connect high beam fuse
Iv got a 2019 ford transit connect and I cannot find the high beam fuse. Iv looked at the fuse box under the bonnet and the fuse box in the passenger footwell and cannot locate it. If anyone has any idea where I could find it that’d be great.
I suspect that there is possibly an error in the owners handbook for this model
Have you checked fuse F31 and F49 in the engine compartment fusebox ?
They are listed as the Low Beam headlight fuses, but that seems wrong as the low beam is normally directly controlled by the BCM and they don't have any fuse. The high beam does normal have a fuse.
Hi
yes I saw that there was left hand and right hand low beam fuses. Maybe il have a look at them. Thanks for the help
I took the fuses out of F31 and F49 and the high beam and the low beam still seemed to work? I’m not sure what to do?
Not sure what to say to that 🤔
On nearly all Ford's that I can think of, the low beam headlights have not been fused for the last 10 years.
What is the problem that you have?
I’m a putting a led light bar on the front of my roof rack and wanted to wire it into the high beam
