Powertrain Control Module
2 minutes ago, Botus said:
I thought it was "always" the wet belt shedding that was blocking the brake VAC pump ?
Seen youtube video of one guy showing the sump off replacement of everything - and I seem to remember he specifically calls out the failing vac pump it the first sign of wetbelt degradation
if I'm not following things correctly... maybe the engine breather starts to draw in fragments of belt into the inlet manifold and then it all goes wrong ?
Knackered wetbelts do wreck vac pumps.  But I thought that was due to lack of pump lubrication.
I would be surprised if belt fragments were becoming airborne at all.
AI making it up ?
Yes, fibers from deteriorating wet timing belts can become airborne and potentially enter the PCV (Positive Crankcase Ventilation) system, which may lead to contamination and other issues within the engine. Regular maintenance and timely replacement of the belts can help prevent this problem.
First things first. It seems ive cracked it. Replaced the boost valve today and took her a blast down the carriageway - twice. No code thrown!!! Woohoo!
Regarding little remnants of the old broken wetbelt in hoses, i have absolutely no idea what hoses it is i need to check / clean out?
Threw the code again today. Going back to garage. Im through with this thing. Plumb out of ideas.
